Fuel Gauge
onlybone
Anyone had this problem please? Any simple fix?
Filled up last week, started engine and fuel gauge took a while to come to life then suddenly shot up to correct level. Today filled up and the needle does not move past the empty notch, however it does move as it drops to idle when the engine is off. I just filled up with half a tank (i hope!) and it only moves to the bottom of all the notches and the empty light is still on.
Must be something to do with sensor I tank is my guess?
Fairly common on the IS200, just fill up and drive around for a while and the gauge will sort it's self out! If you are really worried zero the trip when you put fuel in and work off about 25 miles to the gallon (4.5 litres) and you will be OK :D
