Sound System Upgrades
gary2009
You can go aftermarket headunit and a doible din one would look nice. I would only upgrade the front speakers and put a sub in the back
cheers mate iv already got an aftermarket headunit in it coz of the err3 error but it was only an old one i had lying around.As for front speakers and subs how easy are they to fit and what would you recommend?
it will look standard because the speaker covers are moulded ino the door cards. take the door cards off drill out the rivets of the old speakers replace with new speakers and screw them in, door cards back on job done apart from wiring which is easy enough.
how easy is easy lol?Is there anything id need or a how to on this?
i think all you would have to do is cut the block connector off and split the wires and fit the female spad connectors to it
BUT THIS IS ONLY A GUESS CORRECT ME IF IM WRONG
Ok so there is two ways of doing it :
1) Cut the connector off the old speaker with enough wire attached to connect it to the new speaker wiring then connect to the exsisting connector on the loom.
2) Cut the connector off the loom that go in to the car so you can connect the wires that way.
What ever you do DONT USE SCOTCH LOCKS
anyone have any idea how to put AMP power cable?
Right behind the Battery, you should have a hole in the wall where there is some wires going trough. Of course there is a rubber thingy there to seal of. I just made a small hole in it so that i managed to pull the power cable through, and then used sillicone around it to be sure that nothing leaks through. Then I layed the power cable under the covers in the doorstep all the way back and removed the rear seats, there are holes there where you can pull the cable trough.
