19" rims, 8.5J front & 9.5J rear. Started with the handbook recommendation and monitored tyre wear and adjusted geometry with WIM over the last 5 years to achieve the optimum pressures of 38 psi all round :).
Whatever your tyre and rim size, the handbook is only a guideline, and you need to check your tyre wear and adjust the pressure as necessary. Very simply, if your tyres are wearing more in the mid section then slightly reduce pressure, and if the wear is more at the edges then increase the pressure. If you have uneven wear on one side, book a session with Tony Bones at WIM.
