Fuel Starvation
The main feed will be the fuel rail try undoing the bolt on the end of it and get some one to turn it over to see if it squirts out
the fuel fillter is located in the fuel tank on the end of the pump it is on the passenger side under the rear bench seat
Mike
Hello and welcome to the LOC.
How do you know the problem is fuel starvation?
If you are not familiar with fuel injection systems or car mechanics in general it may be a better and perhaps safer option to have a qualified mechanic look at the problem.
You have to take the air box off the top of the engine and the fuel rail runs along side the engine on the right hand side its a silver metal bar and has the injectors along it
thx for that have done this and taken nut off end and turned engine over and fuel pumps out.so have spark at plugs,fuel coming along rail,any further checks I can make.
ok have now put a scanner on the car and it has come up with p0110 generic 1at sensor circuit malfunction,have googled this and it says intake air temperature circuit malfunction,any help to rectify gratefully received,as the car still will not start.
thx.
