Key Cutting
My local Timpsons is in the local Tesco store, He cut my blank blade in 5 minutes and even took the innards out and transferred because the previous owner had superglued the broken casing...
He did say he could not guarantee the key as they did not supply the blade but it worked first time and still going strong...
Got a new after market key cut today,apparently its got to be done via laser cutting.£ 9 .
The thing is the car won't actually start without the master key in the ignition.
When i put this after market key in the ignition it turns over but doesnt actually start the engine,am i right in thinking i need it programming ?
