Seen Some Repairs In My Time But This Takes The Biscuit!
Similar fix to the one that was done to mine 2 years ago, Except they used a metal putty derivative.
It snapped agin this year so replaced it with the correct part off a unit I got off fleabay.
Repaired a linkage rod in my old Mercs door lock mechanism with an electrical connector and aroldite once.
It worked better than the original linkage rod. (It didn't brake.)
John N
When mine snapped about three years ago I made a replacement from a pair of 6mm Morse marine cable ball joints and a short length of 6mm stainless steel studding. Total cost about £12, which was an awful lot less than Lexus wanted, and will last a lot longerpost-18429-0-47551300-1372099307_thumb.j.
Kind regards,
Alan
Ok I have fitted the other prototype to the car for long term reliability testing but have now come up with a new design.
So this I will call the Mark II version to fit the Mark IV,
post-12144-0-38018600-1372345779_thumb.j
Well done, your ingenuity is to be praised,the units are better than Lexus.
There you go Lexus, stop making all these rubbish Hybrid cars and improve on what you already had.
