Wheel Spacers!
Like i said very good company, cost me £132 for 4 which i thinks a bargain as you can have them down to your own specs so they will fit well with no vibrations. Studs are a little harder to find and a lot harder to fit so be prepared for a fight ;)
Proper hubcentric aluminum wheel spacers with a sensible width and their own lugs will be fine.
I have Eibach spacers on mine, 15mm on front, 20mm rear.
Where did you purchase them from? if you don't mind me asking.
I can't find any Lexus is200 spacers
Surly you are putting a lot more strain on the axle components and wheelbearings...
Yes, you are right, but the calculations suggest that the extra strain at standstill is only 2% up from stock, at 20mm. I'm looking at doing this for Zorro. 15mm at the front and 20mm at the rear.
Stuart, I have never liked the idea of fitting what ammounts to a packing shim between the hub and the wheel, you double the number of joints that could allow the wheel to be slightly off center, no matter how small the tolerance.... The wheel itself sits on a very narrow spigot and adding a shim increases the chances of the wheel not sitting right...
That's a very obvious thing that I had not thought of. If I do decide to get the spacers and then fit them, I will be cautious and ensure that I monitor them. I plan to use hubcentric spacers that bolt to the hub and then use studs that go all the way through the spacer and hub.
