Does anyone know what the high beam lights are
H1 or what ??
I am looking to upgrade them to something similar to these
http://www.aliexpress.com/item/1-pair-lot-Ultra-bright-H7-1800LM-25W-CREE-LED-CXA1512-chips-COB-6000K-LED-headlamp/1182911386.html
I just don't know the make of the bulb
Any help would be great ??
In the ad they say
"Pl note:
This model can not suitable for car with car PC , such as BMW BENZ Volkswagen etc.
This an ordinary type of product that is not band decoder, and It is the same with HID!
Product Description:"
That doesn't bode well to me, but it's your car and your money, so good luck if you go with them.
In case you want to fit LED bulbs, make sure you get the canbus ones - regular LEDs will give a bulb error
I used Canbus LED's on my old Ls400, the error message still flagged up, the bulbs worked and showed no error in a lesser car, just shows the Ls will pick up even the smallest of change.
I stuck a normal replacement bulb in after that and they worked as good as new.
I have replaced mine with canbus LEDs in the past with no issues at all. Might be the quality of the bulb
In this case what you would do is measure the resistance on the LED bulb and measure the resistance on the normal bulb and put a resistor inline to take up the difference.
Just a little way to cheat the computer (basically what the canbus lights do)
