Satnav Disc Removal Guide
Hi, the sat nav disc is behind the clock panel on the centre console.
You can take it out with two small screw drivers.
You will need to push through the hole on both left and right side. I used one screw driver to push out each side and then just use your fingers.
The panel should then just pop out, hope this helps.
To put it back, just simply push back in place. Don't worry this is a very easy process and you should not brake anything taking it out or putting it back.
