Half Stage 1
SParkyWar
I would strogly suggest you DO NOT upgrade the pulley without upgrading the fuelling, if you go to a rolling road and look at the readings with out stage 1 you will see that the fuelling is maxed out. To up the boost on the charger you need more fuel otherwise you will be lean
Si
the tte bods said the bigger intercooler was a load of cobblers cos some is hiden behind the crash bar and the standard intercooler is better than is needed
I wonder what "cobblers" sounds like in German :lol:
The standard intercooler is good enough for the standard system plus a bit more, however our stage 1 intercooler has more efficient airflow and is about twice as big. It would be nice to have the entire core in the airflow, and can be done (as featured on The Monster). For those not interested in going to the time and effort of doing that, the intercooler is still a radiator and will dissipate heat wherever it is, and fortunately there is still a lot of turbulence in the whole of the nose cone area. The cooler the charge are temperature is, the more power you will get.
shiesse ?
Hello,
i have ordered the Lager Intercooler and the Pulley upgrade from TDI because thes are the only items a can get by Mail as i live in Switzerland .. :crybaby:
Have someone tryed is IS200 with this items only ?
If yes can i have some feedback....
have you had it sent yet???? because my appt is in france you can send it to me and then i can pass it on to you, im near L ....... quite often - that way you will not have to pay the swiss tax!! :whistling: :winky:
Si
There was a post somewhere about all the extra stuff you need if you want the stage 1 - fuel lines, fuel pumps, ecu, mapping, etc etc... it's not that simple.....
I think Mark posted it - I will try and find it... :unsure:
