Headlamp Butchery...!
RedLexus
Starting dismantling my lamps this evening , with a view to getting them dark chromed. The first one was a pig to do , I wasn't using enuf heat , being afraid of doing harm.
Now what d'you recommend to remove the old glue (or should that be industrial strenght Cement!) :blink::huh:
yep, hairdryer, it helps if you get someone to do the heating up whilst you do the pulling apart.
i then used the hairdryer again to get as much of the putty glue stuff off as possible.
3M Adhesive cleaner is good.
then to seal up again, reheat the unit, apply a bead of silicone sealent then push it all togther and leave to set..
