Hybrid Punp Failure
hi
have been considering moving up to hybrid but am put off by reports of pump failures at 70-80k
is this something to wory about or should i stay with non-hybrid tech
thought and advice appreciated
les spragg
hi
les spragg
Les,
Do a search on the GS Forum and all will be revealed !
Regards
John
The RX has no such pump. The GS has a weird 2 speed automatic transmission combined with the CVT and it is a transmission fluid pump that has reliability issues.
The only problem with the RX has been the electric coolant pump on the inverter, most if not all where changed under a recall so actual failures were rare to nonexistent.
Many, many, many more RXs sold compared to the GS, and a lot are now well passed 100k miles without an issue.
