Boot Light Doesn't Work
yemgi
My boot light no longer works, I thought the bulbs burnt but it is ok.
When the boot is open, I don't have 12V at the light connector :geek:
is there a fuse or a relay for this light, I have checked the fuses, they are all ok.
any idea?
Just had a look - it's getting cold outside :duh:
The sensor is within the lock on the boot lid. If I push on the level inside the lock the light goes out. Check the wiring connector, unplug and look at the pins for corrosion. Maybe you could take the lock off and give it a clean and a spray with WD40, that may work.
