How Much Refreigerant In The '94?
According to the factory manual the quantity should be 33.6 oz for the 1994 model LS400. Other figures are for compressor pag oil
REFRIGERANT OIL & R-134a REFRIGERANT CAPACITY Application (1) Oil Ounces Refrigerant Ounces
ES300 (2)(3) 4.8 28.2-31.7 GS300 (2)(3) 4.1 28.2-31.7 LS400 (2) 2.8-3.5 33.6 SC300 & SC400 (2)(3) 4.8 28.2-31.7
(1) Total system capacity, unless otherwise noted. (2) Compressor refrigerant oil capacity. (3) Use DENSO/ND-Oil 8 refrigerant oil.
It was in table form in the workshop manual but looks as above when posted. As they say up ere you'll need just over 2 pounds of the stuff.
Based on a completely empty and dry system refill.
