Looking For Replace My Engine Cover For Is250
Hi All,
Recently had a problem with my 2006 IS250, the Check VSC came up, the AA cleared the fault and said take it into a dealer if it occurs again.
But whilst he was under the hood, he noticed that the engine cover was broken, must have occur at a previous service. He recommended removing it as the mounts were damaged and it could vibrate and damage some of the leads running over the engine.
So, does anyone have a good please that I can get another. Trying to avoid a dealer as they will most likely be extremely expensive.
Chris
Or do as I do and leave the covers off, I can see any potential problems develop, for example water leaks or oil leaks with the covers removed, and what purpose are the covers for anyway?
My cynical opinion is the manufacturer put them there to make everything appear mysterious, lift the bonnet can't see anything so go back to the dealer to spend wonga.
