Mk1 Gs300 Overheating
devonbrown
Hi folks, I have just driven 1500 miles to bring my 1997 300 to the sunny Costa del Sol. 1 week after arriving I drove about 50 miles up twisty hilly roads and my car overheated and I ended up with no water. Both oil and water had been checked before and after journey to Spain. I was able to top up radiator and limp back home but I had to stop every 5 miles or so and top up radiator with water. There is no Lexus dealer for miles and the local Toyota dealer cannot take me till Thursday. Help!!! any suggestions appreciated. There is no discolouring of the oil, and the car overheats after short distance. there appears to be no bubbles in water.
  • 1 year later...
Turns out that my radiator is full of corrosion and needs replaced. also the thermostat needs replaced. I have had 2 GS300s,both second hand,both have had badly corroded radiators. Have I been very unlucky or is this fairly common?????
Just replaced my 1993 gs300 rad, totally corroded, have now noticed a lot of pressure on the top rad hose, not leaking any water, is the headgasket about to go, how do you bleed the gs300 system properly.
