My Rx wouldn't start today...
Drove to Luton Airport this morning. All fine.
3 hours later to go home, car unlocked, then dead. No lights, no ignition, nothing ...
Called Lexus Assist ( AA).
30 minutes later, they arrived and the car has started.
The problem?
The connection to my Battery had come loose(!), so it was effectively disconnected for maybe 3 hours.
It took about a minute to be fixed.
It's never let me down before, so I WAS surprised!
I guess the car has to re-learn stuff now. Certainly some of memory settings have gone... But a happy ending.
Top Tip: Keep a coat in your car. I had one ( a high viz ) and was I grateful!
:xmas:
Do you know if that was the original Battery Piers? Mine is the original, and will be 12 years old on March 1st. Is it common for a car battery to last that long? or maybe I've just been lucky. Anyway glad you got it all sorted.
On the subject of batteries I have a Motorhome with a 3 litre diesel engine that has not liked the recent cold weather. It was really flat so i thought I'd try a Jump start pack from CostCo ( PSX3). I was amazed to see the van leap into life and the unit now has a permanent home behind my seat in the RX for emergency use. It has an emergency light, a 12 volt DC out as well as a 5 volt USB out and a tyre inflator  that pumps up to 150psi . So it won't be going back to CostCo !
12 years!
No, mine was changed last year.
Ironically, I suspect when the new Battery was fitted - by a good independent - it wasn't quite tight enough? maybe?
And the CostCo device sounds great!
Happy days.
Piers.
Piers, Thank you so much for your post, re, all electrics cutting out. The same happened to me a few days ago, & again this morning. Thinking it was a faulty relay, I was dreading the bill for finding the fault, on my RX300. Then I remembered your post, & tried it. Blow me down the connector moved when I grabbed hold of it. I couldn't believe it, as I only had the Battery off 2 weeks ago, & has cured fault. Thank you again, & it shows how vulnerable the average person could be, with an unscrupulous mechanic.
Ian Verdon.
24 minutes ago, okbald said:
Piers, Thank you so much for your post, re, all electrics cutting out. The same happened to me a few days ago, & again this morning. Thinking it was a faulty relay, I was dreading the bill for finding the fault, on my RX300. Then I remembered your post, & tried it. Blow me down the connector moved when I grabbed hold of it. I couldn't believe it, as I only had the battery off 2 weeks ago, & has cured fault. Thank you again, & it shows how vulnerable the average person could be, with an unscrupulous mechanic.
Ian Verdon.
Sometimes the best solutions are the simple ones!
:whistling:
