Un Braked Tow Capacity
1 hour ago, luaqhgt said:
Hello
Does Anyone know the legal "unbraked" TRAILER towing capacity of a 2003 - RX300
The unbraked towing capacity is 750kg no matter what vehicle you tow with. It needs to be braked to go higher than this. Unless that vehicle has a lower towing limit on the plate inside the door. Some cars have a zero weight limit in which case they cannot be used for towing.
John
