Skip to content
View in the app
A better way to browse. Learn more.
Lexus Owners Club
A full-screen app on your home screen with push notifications, badges and more.
To install this app on iOS and iPadOS
  1. Tap the Share icon in Safari
  2. Scroll the menu and tap Add to Home Screen.
  3. Tap Add in the top-right corner.
To install this app on Android
  1. Tap the 3-dot menu (⋮) in the top-right corner of the browser.
  2. Tap Add to Home screen or Install app.
  3. Confirm by tapping Install.
Front number plate fixing
Featured Replies
So, how do you all fix your front number plates on?
Mine was stuck on using sticky pads, but fell off in the cold weather.
Obviously I could just drill holes in the number plate and fit it that way.
I was actually thinking of sourcing a number plate surround/bracket which could be fixed to the standard mount, then a number plate slotted in without drilling it.
What set up do you have? If you have anything good let me see what you have.
I've always stuck mine on with sticky pads and have never had a problem. In fact they take some getting off when I'm doing a vehicle change.
I use silicone sealant for my no. plates.
Rough up the surfaces to ensure a good key then use masking tape to hold in place.
Plastic screws.
Sticky pads just make a mess and cant clean/seal underneath the number plate once stuck on. Also had some fall off
Usually sticky pads but on the IS plastic screws because I couldn't be arsed to go to Halfords and I had the screws already. Never had any problems with the pads other than the residue is a bit hard to shift if you do have to change plates. I'm not the handiest with an electric drill either so pads are easier for me.
  • Author
14 hours ago, rayaans said:
Plastic screws.
Do the plastic screws go in the existing holes in the mount? I need to have a look today.
Stucky oads are usually fine, but the mount is only 50% of the size of the plate, so you don’t get maximum fixing. I think that, teamed with the cold weather and frost meant my existing sticky pads failed.
I got Halfords to do it when putting my private plate on. They used sticky pads after cleaning the surface after removing the old plates. Insurance company was paying so cost no bother.
Not sure about the 400h but most Lexus do have mounts and the plastic screws go in there no problem
  • Author
Thank you 🙏🏻
The RX400H has a bad design for the rego plate. The backing only supports the top half of the plate. This is a very annoying issue as I have had to replace my front plate twice due to parking knocks that have cracked the plate. This can be an MOT fail.
So to mitigate my next car park knock I have super glued my new plate to the old one as well as the 2 screws that were already in place. I turned the old one upside down so the crack is up. Now, hopefully, my new plate can withstand a little more impact...
I hope this helps!
I always use No Nails red double sided tape and has never failed.  Just ensure both the plate and bumper are free from dirt and any Car Polish.
A good tip is to gently heat both the plate and bumper....and even the tape and it should not come off.  Used a hairdryer, but as I am as bald as a coot, I use my heat gun.
Don't try any type of this tape on a cold damp day without using a wee bit heat.
I hope this helps!
Its like that on all the RX's
Not a bad design - more like bad driving.......
Note: Your post will require moderator approval before it will be visible.
Join The Independent Lexus Owners' Club
Our community has been built by enthusiasts, for enthusiasts, and proudly run by Lexus owners' for over 25 years. As an independentnon-official club, everything you’ll find here, advice, support, and opinions, comes directly from members with genuine Lexus ownership experience. By being a member you can gain access to active community forums, videos, news, events and more...
JOIN OUR COMMUNITY NOW!
LexusOwnersClub.co.uk (“Lexus Owners’ Club United Kingdom”) is an independent, third-party enthusiast forum created for owners and fans of Lexus vehicles. We are not affiliated with, endorsed by, or in any way officially connected to Lexus USA, Lexus Canada, Lexus UK, Toyota Motor Corporation, or any of their subsidiaries, affiliates, or authorised dealers.
All content, discussions, and materials posted on this website are generated by users of the forum and represent the opinions and experiences of individual contributors. Such content is not reviewed, approved, or endorsed by Lexus Owners Club, ACI LTD, Lexus UK, Lexus USA, Lexus Canada, Toyota Motor Corporation, or any related entity.
LexusOwnersClub.co.uk makes no warranties regarding the accuracy, reliability, or completeness of any user-submitted information.
Any reference to Lexus trademarks, logos, or brand names is used solely for identification and informational purposes. This site does not claim any ownership of Lexus intellectual property.
For official information about Lexus products, services, and corporate communications, please visit the official Lexus website relevant to your region.
Background Picker
Customize Layout
Account
Navigation
Search
Search
Configure browser push notifications
Chrome (Android)
  1. Tap the lock icon next to the address bar.
  2. Tap Permissions → Notifications.
  3. Adjust your preference.
Chrome (Desktop)
  1. Click the padlock icon in the address bar.
  2. Select Site settings.
  3. Find Notifications and adjust your preference.
