Strange noise
After some ideas:
I have a Gen 3 250 and I’ve noticed this noise twice now. Cold mornings on both occasions, it sounds like the noise is coming from inside the engine bay  - it’s more of an electrical noise, like a electric passing through a switch that’s stuck (if that makes sense). Lasts for 3-4 minutes. Turning the radio and blower off has no effect. Car seems to warm up and the noise is gone. Doesn’t sound healthy!
Any ideas folks?
No can't say I have, but even so, there is a big difference between 400kv and 12v
Anyway back to your issue, have you checked the vents for the heater inlet to make sure it is clear of leaves, and any debris?
Also, just a thought have you checked your power steering fluid?
  • 1 year later...
