Hi guys - my 18s go on my 98 LS this week. I have a feeling I'll want to lower the front by 1-2" afterwards. It seems hard to find springs over this side of the pond. I can't afford to import and i certainly can't afford coilovers at the moment. Anyone had any luck?
I don't think there are any lowering springs available, I've not seen any when I've looked. Don't bother importing from the states for a sub brand. I have bc's on mine with 30 way adjustable damping, have got it set on 10 from the softest also on 18s and the ride is very comfortable. They are a bit more pricey but with coilovers you always hear buy cheap buy twice !
Sent from my SM-G920F using Tapatalk
It’s a shame - the h&r springs which were only available in the US are NLA since March last year, they would have been perfect.
So if not coilovers, I guess cutting new springs is the only option, not something I’d entertain.
As they say , never cut spring
find a good mechine shop
get them to make lowering blocks  25mm that will mount on the front strut and rear strut
that all you need , with your stock springs
car drops ,and you dont lose your ride comfort
I made mine 25x25. ,used the stock inserts, and bought longer ht steal bolts
carried out the work within an hour , so not difficult
you can buy the on e bay as well but the come from the US and it was 3 day delivery
What spring rates did you go for?
They came with a preset weight which I think is 12kgf on the fronts and 8kgf on the back. Would have to check and get back to you on that
David i don't know if this might help at all
When i bought my Mk3 from ACLex in 2011  ( he's still on here somewhere I believe ) he had changed my car to DHP stuff and I bought it from him re-converted back to original spec.
If you contact him I guess he might be able to give you some useful info on this subject
5 hours ago, Daveyboy20 said:
If I just get a set of dhp springs will it drop a bit?
20mm i believe - that's if you can still buy them.
I read that the DHP stuff is all NLA - ARBs, Springs, Shocks
