May 14 RX450H Premier Speaker Locations
The ML audio in my RX is meant to have 15 speakers but for the life of me I can only count 14
Dash Centre 1x1
Front doors ... 2x3
Rear doors 2x2
Rear pillars 2x1
Boot Sub 1x1
I count 14, Where is the elusive 15th speaker ;o)
Quote
A centre channel coaxial speaker unit, comprising a 90mm metal cone mid-range and 16mm tweeter, widens the scope of supported frequencies to produce vocals and instrumentals with a greater degree of precision than that of a conventional system, while also matching harmonics between the front right and left channels.
55 minutes ago, Spottedlaurel said:
Out of curiosity, how much difference do the higher spec systems with increased speaker count make?
Totally depends on how old you are and how your hearing is, I suppose. My 61 year-old ears certainly don't hear as well as my 20-odd year-old ones did and I know I've lost some of the higher frequencies.
