Master Key Transponder Lost - Engine Imobilised
Hi Gents,
RE Lexus RX400h 2005
I've been doing a bit of reading here over the past few days namely these two threads;
I have two sets of black keys, one with the transponder inside and the other hollow with the transponder missing. Thinking I had a spare set I never had an extra key cut. I've lost the master key with the transponder inside and now am unable to start my car. I can get into it unlocking the doors using the key but the car refuses to start.
After days of reading up on this I'm left very confused as to what I can do. My options are;
Techstream - will not work without master key
Toyota smart key maker - will not work without master key
OBD2 programmer - again it will not work without a master key.
Is there any way to program a key without the master?
Many thanks!
I may be wrong and I sincerely hope I am, but I think at this stage the only thing left is to either get an auto-locksmith out who may be able to sort it or get it recovered to your local Lexus dealership.
Have an awful feeling this won't end well. I seem to think that an ECU on the car might have to be replaced to sort this. I know with some other makes this is done deliberately to cut down on the 'ringing' of stolen cars. again I hope i am wrong...
You could probably get someone to disable the immobiliser. I doubt it's super difficult for someone who knows what they're doing. Obviously it would leave the car less secure though, maybe use a steering lock?
Actually, not sure about Lexus but I read somewhere that BMW make a handful of spare keys for every car they make and keep them in storage. When I bought a new key for one of my BMWs from the dealer it came pre-programmed and just worked. Maybe Lexus can program a new key for you without needing a working master?
On 3/26/2019 at 6:31 PM, IndyS said:
Hi Gents,
Many thanks!
Any Update?
