Gs300 - Red Exclamation Warning Light
:unsure: Be careful, your light is coming on probably because the fluid is low, the first cause is your pads are worn out allowing the pistons to move further. Check your pads first, when fitting new pads the pistons will be pushed back and if you have previously topped up the fluid you will find the excess lying in the engine bay!
Funny but I thought Gary C had sold his GS too ? Anyway it's only the brake light bulb if you press the brake and the light stays on ... otherwise suggest fluid level, caliper (sticking ?) and worn pads ...
Went through all this myself over past few months, starting with brake pads, fluid etc. As it was intermittent, I dismissed the bulb being blown, but knew that when the warning light came on, my o/s brake light went out.
I ended up re-soldering the bulb holder wiring/housing and replacing the cable with new. 2 days later the warning lamp came on again!
Turned out to be a faulty bulb after all (not blown - but had a dodgy fillament connection)
Regards,
Steve J.
