Where is the paint code kept on 2007 IS SE
Hello Lexus owners, Could you please advise on where the paint code is kept on 2007 IS SE? I have seen some models have it on the inside door, but I can not see it on my model?
Thank you.
Best regards
Julian
Hi Julian, have you checked both B pillars for the vehicle code stickers?
If there aren't present, then you can run your VIN# through online decoders to figure out your paint code.
Good luck,
Cheers, Lee
6 hours ago, Joolsd said:
I am not sure which is the code? I think it might br this: Color Code: 1G0Smoky Granite Metallic?
Correct. C/TR stands for Colour / Trim so your colour code is 1G0.
Only go by the colour code, not a name associated with it as names vary between countries and between Lexus and Toyota vehicles.
  • 4 weeks later...
