GS300 DVD/USB Full Screen
glass
Hi y’all
I’m new on here so go easy on me. ☺️
I’ve recently purchased a GS300h 2015. Excellent car.
Quick question:
With which option can the large video screen display the USB video in full screen?
(I’ve tried and am only getting an ‘expand’ option which does not give me a full screen.)
Thanks in advance.
Uhm, probably the point is that video is 16:9 ratio, so if you also set the screen for single vision, the height of screen does not change 🙂
Expand option only cuts upper and lower  of video image so that you can see a bigger image losing slices of original source.
Thank you, Zotto.
I have tried this and the video is still shown in only part of the screen and not full screen.
Maybe the fullscreen option is only for 8 inch screens?
12" screen is for double data display, and usually I let it divided left side with map and right side with radio or energy monitor, bur I tried sometimes single display on all size screen, with maps,  and it works.
How did you do this? I can only get navigation on the left hand screen. Mine is a 2014 my.
I the vertical line  where you select the secondary screen (radio, engine data etc.) there is a ">" sign , click there and screen becomes single.
I don't have that on mine. All I can do is put the right hand screen to the left. Cannot expand the map screen. Maybe yours is an updated version.
