ghost_killer 10 Posted February 13 Share Posted February 13 Hey all, As I removed the rear lights to change to LED indicators (hyper flashed even though they said it wouldn't so sent them back), found a slight issue when fitting the rear cluster back on one side (haven't tried the other side) the bolts doesn't seem to tighten so I think it must be the 'grommet' part no. 90189-06235 that seems to be worm and needs changing - circled and that arrow in red on the pictures those pics show the near side part of the car. Anyone know how to remove them ? I haven't yet tried to see if they come out that easily, I can get new ones easily just not sure if there is a way to remove them. Quote Link to post Share on other sites
Mr Vlad 273 Posted February 13 Share Posted February 13 Can you not use a self tapping screw? I'm quite surprised that the 'grommet' part has worn as it's basically not a moving part. Perhaps a previous owner has stripped it's thread. Quote Link to post Share on other sites
Paul Brooksbank 107 Posted February 13 Share Posted February 13 Take a piece of copper wire, the earth off 1.5 mm twin and earth and bend it double, then slide it into the hole so the tails are sitting on the rim of the plastic insert. Then try the screws again. Quote Link to post Share on other sites
200h 586 Posted February 13 Share Posted February 13 i had something similar the other week on the drivers door panel everytime i closed the door i could feel the panel move slightly i found the thread had stripped so i tapped it M6 and used a different bolt instead. Quote Link to post Share on other sites
Paul Brooksbank 107 Posted February 13 Share Posted February 13 Take a piece of copper wire, the earth off 1.5 mm twin and earth and bend it double, then slide it into the hole so the tails are sitting on the rim of the plastic insert. Then try the screws again. Or screw the thread onto a ball point pen spring and screw the lot back in. The spring will form a helicoil. 1 Quote Link to post Share on other sites
