Marcus, is there any useful and provable service history with the car being sold .... particularly the change of cambelt, waterpump ............. and pulleys check .......  date, mileage and by whom / which Lexus Main Dealer
and has anybody checked with Lexus that the original RECALL work has been done with regard to changing the Starter Motor ? a specific issue with the Mk3 and not always seen to I understand
.............. and is it a NEW alternator ............. or simply the usual Exchange Reconditioned one ..........  and who by / from ?
Malcolm
Hey Malc,
not a real consistent services history, I know its been mostly taken to a local independent garage in Hitchin from the receipts and mainly MOT certificates, near to where I live. I have no idea about the recall, the previous owner had it since 2000, I brought the car from a someone he trusted to sell it for him. It was probably a bit of a gamble, but I will have a look at it properly on the ramp this weekend if it's free and take some photos of the underside. The water pump is working fine and all the electrics work on what I've tested so far. and yes the alternator is NEW, it was brought from an eBay shop. I will take a photo of that when it arrives and put that up here.
thanks
Marcus
well Marcus, a  NEW  OEM  alternator is the best part of £1000 from Lexus ..........  an exchange reconditioned one is maybe £4/500 from a known and reputable supplier
£1000 for alternator? I've got to ask the same question, where do you get your parts from? Rockauto is the place to go, or buy a second hand one for around £60, and spend another £40 or so and get it reconditioned before fitting it
well Marcus ....  Lexus itself for OEM Main Dealer ............ and other usual reliable suppliers for exchange reconditioned
I haven't checked   Lexuspartsdirect .......... maybe you could check them out |?
maybe check out Amayama and Rockauto ( USA ) too
yes for sure, that's the price quoted by Lexus when mine went at 208k miles ( I think that was about the mileage )
You got robbed if you bought it. I remember I had a toyota celsior ls400, alternator went on it, I bought a second hand one from breakers yard, had it reconditioned, and then fitted, cost me total of £100
yeah I agree with Messi, might have got robbed their. I've brought a new one for £190ish...and just got a quote from my mechanic who lives 30meters from me who called a company named Beds Battery (where he gets all his lorry parts and car bits) and they quote 190 trade or around £220 over the counter for normal folk. thats OEM.  just to be sure I wasn't being done over by another eBay scammer.
Edited by Mbish91
Spelling
I thought that too had I bought it
It's well documented on here somewhere .............. I bought from EurocarParts or some such recognised name and think it was about £400 exchange and reconditioned
The Honda Legend alternator went too shortly thereafter sadly and NEW  OEM  from the Honda Main Dealer was about £1000 too
One doesn't often get the opportunity to delay fitting a replacement alternator to one's car when it's in daily use and recovery by the RAC is in throes:wink3:
ordering from Amayama / Rockauto doesn't get you the part overnight sadly
they sure look the part .............  good luck with the sale .....  do keep us in the picture ....  we're always interested in these things
Sooo, after getting a barrage of idiots on Facebook and eBay, I've returned here to see if any would be interested and not looking to waste each others time!
I've dropped the price to £2900 which I think is fair. Alternator has been replaced and rear braklines have been replaced as well, as well as the front right spring and had an oil and filter change, she runs great and the brakes are finally as they should be!
if you're interested, 07599 084 823
Marcus hi
so please remind me ......  how was the excessive structural corrosion dealt with and the 4 x perishing tyres ?           from the Nov 2020  MOT
and was the opportunity taken to change the cambelt, waterpump  ....... and check out the cambelt pulleys ? at any time recently / over the past few years
Repair immediately (major defects):
  • Nearside Rear Suspension component mounting prescribed area excessively corroded significantly reducing structural strength (5.3.6 (a) (i))
  • Offside Rear Suspension component mounting prescribed area excessively corroded significantly reducing structural strength (5.3.6 (a) (i))
  • Monitor and repair if necessary (advisories):
  • Tyre slightly damaged/cracking or perishing all (5.2.3 (d) (ii))
hey Malc,
I've own the car a total of 5 weeks.
the rear suspension mounts with the structural corrosion wasn't touched, I don't have the budget to plough money into to fix it. But hey the new owner can feel free to replace it or put the car on coil overs. The Tyre perishing is slight as describe above, I've been driving around on it fine. again, if the new owner wants to put new tyres on it feel free, 3 of them have 5mm of tread and 1 has 4mm. I didn't replace the water pump as that is working fine. all the pulleys were moving fine when I replaced the alternator, the tension springs back strong as it should.
This isn't a perfect car hence the price. If it was it would be going for WAY more, just check eBay for the price some are going for 6-10k. This car needs a little work, the chassis it's self is good. the paint work is good for it's age and does have some imperfections, but it is almost 30 years old. The interior is good. So I think the price is reasonable at sub 3k. other cars non running and spares or repairs are going for 2k.
If you want more questions in detail mate, I suggest coming to have a look in person.
I'm based in bedfordshire and can be contacted on 07599 084 823
I had a 93 LS400 from 95 to 99, did 140,000 and replaced dash and plug leads. Had a 2003 LS430 from 2004 to 2012, did 240,000 and replaced one steering wheel motor, radiator and had two minor issues with air suspension sensors. Preferred the 430.
Hope you thoroughly enjoyed her too 😊
I've had mine for 10 years now, and driven 110k miles of the now 233k miles she's covered , and before that a Mk1 and a Mk2 Ls400, all concurrently and for 20+ years now and probably covered the best part of at least a quarter of a million miles in them overall ..........  marvellous, brilliant, fantastic, virtually trouble free motoring too :yahoo:
BUT I have always tried to do preventative maintenance .......  like the cambelt, pulleys, waterpump sorted every 10 years / 100k miles say
AND whilst tyre tread is quite ok at 4 / 5 ml mine never got to be underused and suffer the dreaded sidewall perishing ............ to drive in fear of that horrendous blow-out potential and in a 2 ton car .....  blimey, that would be some spectacle eh !:wink3:
