Any Tips On How To Keep The Emissions Low?
jasear
give it a good run before the test and rev it quite a bit on the runs eg running near the rev limit for a km or so - this often helps.
if it doesnt then get the lambada sensors checked
cheers dude. Will do that. Just out of curiosity though does it effect the emissions if the car has just not been driven for a few months?
Hi,like fluff says check the lamba sensor,they over time lose the top and bottom areas of the scale,on most cars its on the down pipe off the exhaust manifold.When worn they may over fuel the car and that will give you high emissions.
Has the car been modified?
not sure abt that! Wouldnt be surprised if it has been modified!
Probably the mods that are causing high emissions rather than a fault O2 sensor. Also make sure the air filter and MAF sensor are clean.
