Which Tyre Gauge and how Accurate
 Hello to one and all I purchased this Tyre pressure gauge (see photo) from amazon last year to see how accurate it was I went to my Lexus dealer to compare with there pressure gauge they said your gauge is -1 psi to ours I also checked with my local tyre shop the same -1psi  how do you check your gauge
Well, I tend to use two tyre gauges, one on my air pump, and a small pocket one.
They are both +/- 1 psi with each other - and I'm comfortable with that.
I'm quite prepared to believe that all tyre pressure gauges will have an 'accurate' lifespan - so when these two start to disagree more strenuously, then I'll replace (one of?) them.
36 minutes ago, Marlinleg said:
 Hello to one and all I purchased this Tyre pressure gauge (see photo) from Amazon last year to see how accurate it was I went to my Lexus dealer to compare with there pressure gauge they said your gauge is -1 psi to ours I also checked with my local tyre shop the same -1psi  how do you check your gauge
I have a couple of these TireTek gauges.  They’re supposed to conform to a standard that demands an accuracy of 2%.  Considering that you could be +- 1psi just reading a dial type gauge - and that you don’t know how accurate the dealer’s gauge is - I think you can regard this result as being well within acceptable limits!
Incidentally,I found them to be an excellent company to deal with.  I had a problem with first one I bought and it was replaced without a quibble.
I have this one,easy to use and reads in different scales. Had it now for 6 years i paid £29 back then. It came with a calibration cetificate of +/- 1 psi
Edited by McRattlehead
add detail
I bought this, -GS/TUV Approved and ANSI Grade B accuracy ( 2% accuracy).
RACE X RX0014 Tyre Pressure Gauge
Total accuracy isn't really necessary, just check the tyres regularly and if they are wearing evenly across the tread, all is fine
I have this one too (thanks to @NemesisUKfor the recommendation a while ago) and am pleased with it. I especially like the fact that it's easy to insert into the tyre valve and easy to read.
I have a small Battery compressor with a digital gauge which I bought for my bike. It seems to match the readings I get with my other pumps, so I'm happy with it. It's good for inflating the bike tyres, and fine for topping up 1 or 2 psi if the car needs it, but takes a while to do much more than that on a big car tyre. Mostly it just lets me check that all the tyre pressures are the same.
https://www.amazon.co.uk/Xiaomi-Portable-Electric-Compressor-Operated/dp/B09JZWJ2QY/ref=sr_1_40?crid=RSZ055XDIPJC&keywords=battery+tyre+pump&qid=1661791535&sprefix=battery+tyre+pump%2Caps%2C1932&sr=8-40
