I have a Lexus IS200t Premier which I assume has TPMS which it does because there is a tyre pressure warning light that has come on and I’ve seen the sensor in person but wanted to ask why I can’t view pressure readings on my dash? Is this an American thing only or a never thing? Surely there is something wrong?
When I go to the central screen in my dash on the ‘i’ section and go through the options it shows where the tire pressure reading would be completely blank with no figure of the car either. Just would like to know why I can’t check my readings although it clearly has the TPMS and it is a Premier model so I’d expect it to have the ability to give readings.
Hope someone can answer my query, thanks in advance.
My IS250 Premier has TPMS but doesn’t display pressure readings.  In fact it only indicates that one - or more - of the wheels has suffered a drop in the preset pressure.
The Manual doesn’t indicate that it can do any more than that. Do you have a Manual you can check - or download from the Lexus site?
