Hi I've a problem with my Lexus is 220d as I've ignition on dashboard but when I press the start button all I'm getting is  a click and nothing else.
I'm not a mechanic myself and can't work out the problem.
Any help on what it might be or how I can resolve this issue would be appreciated  guys.
Many thanks Michael.
If the Battery is good then you need to determine where the click you are hearing is coming from. You should hear a click from both the starter motor relay and also the starter motor solenoid. If the starter motor solenoid is clicking but the motor isn't turning then you need a new starter motor.
An auto electrician, or even a normal mechanic, should be able to diagnose the issue quickly.
