Wanted ! Wanted! Wanted!
GALLA_4
Guys
I am looking for the springs from an IS200 Sport that give the -15mm drop.
I am thinking that someone out there has a set that they are not using after a conversion to Eibachs or similar. I would be looking for a set that came off a 2002 model upwards.
I am over here in Ireland and the roads are not the best so the Eibachs would be too low however the -15mm Sport springs would be spot on!
Thanks all for reading!
Regards
GALLA_4
Guys
Regards
GALLA_4
You have PM
I really wanna keep like with like! ie put IS200 springs on an IS200!
Mr Morse thats a very kind offer and I really appreciate that! Your a good guy! With things like springs and brakes I am a bit concious of safety and would rather put model parts with model parts.
As Anees pointed out about I want the late 2002 onwards springs to give the -15mm drop.
The eibach's on my IS300 ..... were originally from an IS200 ............
Scareface
Would the Eibach be uncomfortable going over bumps? The roads here are not as good as UK roads
SF's Eibachs will have a softer compression being originally an IS200 part, so his ride won't be as hard as with IS300 Eibach's
So, whether you go for OEM IS300 springs or Eibach's your ride will firm up considerably....and you'll learn to take those potholes and speed bumps reeeeeal easy!
