Caliper Stickers
Doodlebug
Which way up have you fitted the front Lexus caliper stickers?
The same way up on both sides. (So the L is at the top or bottom on both sides)
or
So they can be read from the same direction. ( From the front of the car or the rear) so the L will be at the top on one side and at the bottom on the other.
Also
Has anyone fitted the stickers curved to follow the shape of the caliper, if so pictures please and how did you do it?
:D :D
or
Also
:D  :D
The "L" stickers go on only one way round, they are not double sided. Pete Jenkin does the curved type sticker that follows the shape of the caliper, they look vey good.
or
Also
:D  :D
Mike
They can go on more than one way round. With the L at the top on both sides of the car or the L at the top on one side and at the bottom on the other side. They do not need to be double sided to do this.
If that makes sense.
:D :D
OK thanks.
So has your other front wheel have the L at the top also?
:D  :D
It must be at the bottom...
They can be read normally as you look at them.
Off the top of my head i cant really remember as i've not seen the car for so long
agreed...
The logo's are straight, should be straight... and should be able to read with minimum of head tilting.
As for the rears i've sat the L logo horizontal to the floor. So it can be seen while having your head upright. (if that makes sense :duh: )
I shall get pics of mine up, seeing as i only did this 2 weeks ago myself.
