Sc300----is300 Engine
XBoostX
According to http://www.toysport.com/ the SC300 (Or Soarer as its better known) came with the 2jzge engine between 1995-1999.
The 2jzge head yes indeed can bolt up to the supra twin turbo block (2jzgte) but there is no point in doing this.
The 2jzgte engine is perfect as it is and fitting a 2jzge head to it will prevent it from using the turbos it comes with.
What exactly are your plans? Perhaps i can point you in the right direction...
I have a few friends with IS300's turbocharged with factory IS head(ported and polished) making 500+ RWHP, by doing this they have kept a pretty smooth idle and since the heads are VVTI unless you open her up it will run like a lexus. I will also run the aem plug-n-play system upgrade the fuel system and might have to change to rearend and or rack-n-pinion. I am open to all your suggestions so please dont hesitate to tell me anything. Thanx
And if anything i said is incorrect please correct me. Thanx
