Knocking Sound From Aristo V300 - 1999
JS820
WOULD SOMEBODY TELL WHAT IS THE PROBLEM IF THERE IS KNOCKING SOUND IN THE FRONT WHEN PARKING OR TURNING AT LOW SPEED?
I'VE REPLACED ALL SHOCKS TO THE NEW FACTORY STOCK, AND ALL FRONT BUSHES & BALL JOINTS, IT STOPPED A WHILE BUT NOW APPEARS AGAIN. IT'S ANNOYING...
If it is when you are at real low speed and on full lock one way have a look in your wheel arches for something catching - I had something coming away from the inner skin on a previous car and on full lock I guess the wheel must have just caught it and it used to beat like a drum!! I'd changed bearings and steering joints before discovering it. :blush:
Thanks skeet and goodoldgrandad
i've checked it is nothing related to the inner skin
i've also changed the upper and lower balljoints (actually i've changed the shocks, together with the brushes of anti-roll bar, all the arms in the front). it doesn't help.
I've schedule to change also the brake disc and see if the situation can be improved (but actually I don't think the sound is coming from the disc).
