Retrofit Multimedia
Anything is possible but I think it will cost way, way more than you'd want to spend.
It's not just the head unit but also the ML amp, speakers, rear camera etc.
It would probably be cheaper to trade your 220d in for another 220d with MM and suck up the difference.
Or, the other way to go is aftermarket with regards to sat nav, Bluetooth, rear park camera etc.
I agree, I would have thought the cost of the headunit alone (let alone the speakers, camera, etc.) would be more than it would cost you to swap the car.
Is it possible to fit an aftermarket headunit to the new IS with the way the stereo is in two bits?? ;)
