Help Needed Sharpish Please!
right i have now a big prob i hope u guys can help with
2 plonkers were fightingthe other day and my drivers side door panel got dinted
i need to no how to remove the door panel to get to the panelto pop it out it also has stretched the paint and given it the orange peel effect
i no a bit about how to reduce the latter but any help would be appriciated
i want to have a go at it myself before i take it to bodyshop my mate owns one n said have a go urself if you dont get it right ill sort it so y not
undo screw behind door release handle, also one in the bottom of the small hand grip .
remove door handle release surround
pull door card away from door from bottom edge
disconnect courtesy light
lift off door panel
disconnect door switch plugs
thought i may to be fair though the top one is hardly noticable its only real tiny so may try your suggestion on the main one and see if it works and how its looks in the other case of removing the card to get to the top dent are the hard to knock out or not
