Replacment Windscreen
GWilso
I've had the windscreen replaced a few days ago due to a crack and I now have more creeks and rattles than before Coming fom front door(s) area
Has anyone experienced this before?
i'm wondering if the screen has been fitted correctly? or it's just weeken'd the structure slightly or maybe it just takes time to settle in.
Any thoughts welcome
Gordon
Gordon
hi mate if you have a look on the forum somewhere there is a bit about people that have a new front windscreen fitted and when it rains the water leaks into inside the front right side i think and can affect the fuse/relay box..if the windscreen isnt sealed properly...im sure there are some people on here that will tell you more about it....who fitted it for you?
Ok i'm getting worried now especially with the big freeze coming
you should be ok but just get it double cheacked and make sure that its sealed and bonded properly...if ya lights start going funny it means water has got into the inside of the dash and it can cause the relays and fuses to play up and rust.
