Help Please
CIJ
Alright,
I know its been brought up before, but my cars just been in for the sus fitted, all i wanna know is that the ABS light has come up.....has the guy fecked the sensor? I was out for my bday drink last nite so my heads a bit sore so please dont say go searchin :whistling:
Thankyou!!!!!!!
Chris
Cheers Chris, is there any way to tell which one, and the all important question.....how much to fix??????????
Yeah it was a good nite.....cant remember quite a bit of it.....mmmmmm jack daniels!!!!!
Dont think they'll of removed it but hes havin another look :glare:
they need to remove it to do the suspension properly, but sounds like they have damaged one of the wires - think they are about 120 pounds each.
u need to pull the fault code to see which one.
Cheers rob, 120quid....this coilover change is gettin bloody expensive, the TRC light is also flashing, does this happen when there really damaged?
Also with that flashing does it mean that the traction control is on or off??
Thankyou
Rob, can i ask how you 'pull' up the codes? Im guessing that it aint by the OBI11 reader. Will my local garage be able to get these codes?
Chris, remember the code reader we had at the blackpool meet ? any good garage should have one to get your codes :D
Well ive been up to my mates at the garage, and had the computer plugged in to pull the faults and it cant find it!! Then one of the lads nipped out to get his 'snap on' one and it couldnt find my car :o so there gonna have to test the resistance of each sensor, what i wanna know is what is the reading of a good one? Also where will they pick the wire ends up from?
The one i had in Blackpool was Snap on, it found your fault no problem, i dont think he has up todate softwear in it mate :o i know Steve keeps his up todate, with lexus softwear as he works on lots of lexus now B)
I was only in Manchester monday n tuesday...grrr!!! So it should it bring up the ABS sensors?
It should bring up your fault that is making you light come on Chris, including your ABS sensor, if thats at fault :o
It saying something if the snap on code reader dont even know your car, it must be well out of date :o
The code reader looked brand new!! I mean it was theys personal one, so it may not have been loaded with all the cars....i dont know?
What else could be bringing up the ABS light? I did mention that the TRC light flashes too, does this mean its a rear sensor or could be any of them?
Chris, it could be any, re the code reader, it the level of software you buy that counts, I know Steve has just payed £8000 for his new one, his old one that i took to the meet was £5000 :D
Ps, just seen you 1st post, if the light was not on before he did the work ? then i would say he has done while working on your car, Adie had the same problem when someone changed his too :o
Yeah its been done whilst the car was in!! Gutted is an understatement!!
Its a bit of a shame that they do the scans for free for me and anywhere else wants paying....but the computer they used before brought up the engine fault!?
