Help i have just taken of the indicater but can not remove the headlight there is not enough room do you have to remove the bumper to take out the headlight i need to do this as paint on the bottom of headlight is comming of
yes i did and the indicater took about 10 secs to remove and about 5 mins to remove the yellow much easier than i thought .all the bolts are removed on the headlight and it is loose but no room to get it out it is doin me ed in .it is a bit like the rubics cube :crybaby:
Done indicaters but bottom of headlights not so good .the grey on the bottom had worn of but when i sprayed them thew solvent in the spray took the rest of the paint of so looks even worse now .so will take of all paint and start again.
Just completed my first mod and it looks fine .Jac114 it was a lot easier than i thought it would be the only thing i would say is be carefull of the opening that holds the bulb housing it is made of weak plastic and when you put the pliers in to break up the orange reflecter it is easily damaged .Headlights were a pig to get out though :)
Not realy you do have to use some force .It is realy just a case of grabbing it with the pliers and turning until it breaks into small enough peices to fit through the hole .I would have done it months ago if i knew it was this easy go for it ,it won,t take more than 20 mins but be carefull of opening as said above
jac
as mudzs said be very careful of the opening as all you have to is look at it wrong and you've damaged it
go 4 it mate but take your time. it'll look 100% better together with your new side repeaters
jaybo
i bought some orange bulbs at my local garage but they still show orange through the lenses ,can you buy clear bulbs that flash orange or is that a very silly question :hehe:
orange bulbs will flash orange :blink:
you need the silvervision bulbs....that are silver.....but flash orange
