Injectors
Yeldarb
Bugger thats that plan out the window.
lol jut throwing more fuel in won't help you need to get air fuel ratio up. Increasing injectors is handy when you are using forced induction as you throw alot more air in therefore require more fuel to keep the ratio constant and not lean out too much.
What exactly are you looking for and what have you done already to your motor
At the moment the car is standard apart from 18" alloys, hids, sport body kit. I would like to increase the lower to mid range pick up, not to interested in top end speed as I like my clean license. Without spending the fortune that a S/C or turbo would be as I have a MR2 turbo engine and 'box in need of a rebuild (cracked head and big end rumbles) that may well go in late next year, depending on how hard the conversion would be.
