Which Clutch?
Asi
hi there,
my clutch is slipping now and looking to buy a uprated clutch so i was wondering which one would you prefer.
helix organic clutch.
exedy paddle clutch organic
the blueprint clutch
or item number 320305872293 on eBay
thanks
I had an OEM one that lasted 50k miles with the supercharger, I just changed it for another OEM one and I am well pleased with it so far
Blimey, I did over 30k miles with the suprecharger and thought I'd done a lot :lol: Same as you though mate, was fine with OEM and the Blueprint - only had to replace the OEM one after it got ragged up and down at one JAE!
Im thinking this is the route im gonna go down...car had done about 90k when I put the S/C on and its at about 108k now but the bite point is so low im convinced its ready to go. What was your bite point like yemgi? You remember what yours was like Aido?
On the Blueprint one mate? From what I remember it was exactly same as the stock one? Daft as it sounds mate when my original clutch died for some reason - and I never did figure it out - it would only slip when it was raining.
On a dry day I didn't have a problem - rainy day - it would slip like mad.
Had it swapped and never had the problem again - maybe it was just on the way out?
What was your bite point like? Was it high or pretty low down to the floor? Mines only got about 1" of travel before biting...
I do notice is more on a rainy day, car seems ok in the dry as far as slipping goes. Not that its ever so noticeable. Is their a way I can test it?
To be honest mate I can't really remember the specifics - I know the bite point never changed in the 30k miles I did before changing the clutch and the bite point was exactly the same after having the Blueprint one fitted?
