Fluid Brakes Upgrade
Hi, I received today my Goodridge brake lines. I would like to know if it is worth it to upgrage also the fluid brakes. Will it make any difference in the braking? If yes, which product do you suggest? I also changed my brake discs and pads last week with EBC and they are superb in performance compare to the OEM. I suggest them to anyone who wants to change their front brakes
Yes it does matter,
you certainly shouldnt put dot5 with any of the others.
and you should only really have one type in, ie flush the other out if changing number.
you need the system completely empty and dry before putting 5 in, but not 5.1.
