Question On 1G-Fe Camshafts
Hey peeps, apologies for the very basic question...
As far as I'm aware, the IS200 has a twin-cam (DOHC) engine, as mention here and several other sources.
However, I was looking at the cambelt replacement walk-through and noticed that there was only a single sprocket for the camshaft?
I'm new to Toyota engines, but I clearly remember that my Nissan RB20DET motor, which is also a 2-litre DOHC inline-6 unit, has two cambelt sprockets for its twin-camshafts, instead of one.
Could anyone explain to me how does this work in our engines?
  • 11 years later...
The sproket is atatched to one of the camshafts. the camshafts should be linked togheter with a gear making them spinn relative to each other. and thus with the crank throught that one sproket and gear.
Just now, HS_Norway said:
The sproket is atatched to one of the camshafts. the camshafts should be linked togheter with a gear making them spinn relative to each other. and thus with the crank throught that one sproket and belt
