After Flat Battery !help Please
Hi all
iv a bit of a problem,after been parked up for 2 weeks my Battery was pure flat,not even ignition lights so i removed Battery and put it on charge over night. then today put it back in my 2000 is200 and it started perfect,i went for drive and came home,this is where it gets weird!! i turned off car and took out key and my ignition lights were on,batt,engine light etc...it started straight away then turned off car again and thelights still on,even the heating working without keys.
i had to disconnect the Battery now over night to have the lights off
If anyone could help me it would be great,iv searched forums and couldnt find anything :(
Oh i did have bodywork done to left (passenger) wing few weeks ago if this could have done something to it
Thanks in advance
Check for moisture in the fuse box in left footwell. Only other thing I could suggest is a reset of the ECU,
IS200: Resetting ECU
Make sure the ignition is turned off
Remove the engine bay fuse box cover
Remove the 20Amp/25Amp EFI fuse
Remove the 15Amp ETCS fuse
Wait 30 seconds
Re-insert the two fuses
Install the fuse box cover
T his is sometimes advised to reset errors and if changing to higher performance fuels such as V Power.
EdGood luck
Thanks for help guys,iv checked for moisture and all seams perfect. .i done reset of ecu and no change. .i removed the dome fuse in passenger footwell and everyting went back to normal except for no remote locking or alarm. .so im tinking the main problem is there somewhere. .i must look into the ignition switch and see what happens. .will keep posted. .thanks again
