just had 2 tryres on front of the gs one of the studs sheared tightening up were can I get one ?
Strange? this has happened to me, is there a problem with these bolts?
did you change yours ?
Yes I bought new ones from Lexus, they cost £4.86 for two in 2010.
I would have thought that the alloy wheel would have failed before a stud would break!
You'd be surprised how easy they are to snap. A long breaker bar would snap one with very little effort. The wheel is much stronger than a stud.
One reason they should be fitted with a torque wrench not an impact hammer. They are not stronger just put under a different type of load.
