3D Printed Iphone 5 Dock
I couldnt find anything good enough to fit an Iphone 5 dock into my car so i decided to design my own dock that would fit in the ashtray.
I used 123desidn to design the dock and sent the stl file to a company, who 3d printed my design and delivered it to me.
I used plastidip for the finish and a glue gun to secure the cable and dock into the ashtray.
I will not be selling these, but if anyone is interested i can give them the .stl file ( the 3d printing companies use this file to print the objects) and a guide on how i installed it.
I know you said that you used a glue gun to secure the cable. Could you explain that a little more. It seems like the actual cable could still wobble? How sturdy is the cable?
I designed it so that it is a near perfect fit for the cable. The glue holds it in place and there is no chance of it moving. I tacked it in place with superglue before using the glue gun to make sure the cable didn't move when applying the glue.
The dock only charges the phone. I use the belkin air to play my music through BT. You can see this in the pictures of my armrest.
  • 2 months later...
Well done! Amazing work, you just gave me an idea what to 3D print next. I just get my rubber filaments at 3d2print.net and they look like this: http://www.3d2print.net/shop/filament/elastic-filament. They say this is a bit tricky filament to print with. Any issues you’ve encountered using such filament like this?
Not sure I'd use a rubber filament for this? I think a rigid material with a plastidip coating would be more effective.
I do have some ninjaflex which similar to the product you linked to. I haven't used it yet but documentation suggest it sticks well to Kapton tape and needs a slow travel speed to compensate for the compression between the extruder drive gear and the hot end.
Chris
  • 4 weeks later...
