Air Con Light Flashing
hi all
this is my first post but have been around a bit
1 aircon light blinking-is the system in need of regas?-switch off/on and works ok for a while
2 any way to lower front seats-below electric limits to increase access headroom ie reset seat rails or similar?
thanks
les spragg
Hello,
Don't have a clue about the seat height, but have you checked the filter behind the glovebox as if this is blocked it will cause problems with the air con, Mine would switch itself off and when I put it back on it would work for a while so it sounds similar.
Oh, welcome to the club.
Pete
