Ct200H Advance Connect Nav Controller Not Working
Dave_5150
A couple of days ago my contoller stopped working. The blue light on the panel still flashes when buttons are pressed but nothing happens on the unit. I presume it has lost its connection but before I book it in with Lexus is there any button combination I should know about to resync the controller with the unit?
Dave
i know its probably stating the obvious but have you checked your user manual to see if there's anything listed about it.i cant suggest anythink else as i dont have the nav on mine.
Hi Dave_5150
I have been suffering same problem quite a bit lately and the nav was frequently not connected to the remote. Have tried the power off/on and it's hit and miss whether it works or not. In fact Saturday I tried this routine 10 times and it failed to work. So as a last resort I turned off the power and then ejected the SD card and the put it back in and it hasn't failed since. Fingers crossed it's fixed.
